This option is not found, Where do I find the Partner ID?
"After adding your API key, you will need to add the Syncro Partner ID to your GravityZone.You will find this partner ID on the Bitdefender App page inside Syncro, and you will add it to GravityZone here under the “Bitdefender Partner”:
