As per title.
Is there a way I can export a copy of my syncro data?
Spreadsheets would be fine, some kind of standard database format would be fine too.
Just wondering if the feature exists.
As per title.
You can reach out to support with a ticket and they’ll be able to provide a link that triggers an export.
https://.syncromsp.com/reports/downloads?export=true
You can also use the dropbox integration for invoices and tickets.
Unfortunately that’s about all you can get out of Syncro unless you rig up something with the API.
Currently in progress.
I need this to get backups and to have a secure log of changes over time.
