I must be missing something here. I have a few calendar issues. Outlook will not sync to Syncro, Syncro will sync to Outlook. I have unlinked them and set it back up with the same non-working results. I also have this issue with my public calendar matching my private one.
Anyone? I thought support was supposed to chime in here? Like the FB group.
Hi ncalvert! Sorry about that! A few posts slipped through while the community was still fresh. It looks like you have two-way sync enabled so that’s good.
A few follow-up questions…
- Are these recurring appointments? Recurring appointments aren’t supported for sync, but this is a great feature request.
- Is your integration 1:1? Make sure each user/tech re-authenticates their own calendar. An admin re-authenticating everyone will override their calendars.
- Is this a shared calendar? Calendar sharing isn’t supported.
- Are these appointments that were created after integrating? It will not retroactively sync old appointments that were created before your integration.
- Have you given the appointment time to sync? There can be a delay of up to an hour. This will likely be a yes, but I figured I would include it for anyone else that runs into this.
If you still have trouble after checking through all these points and making any necessary corrections then re-authenticating, go ahead and contact us at help@syncromsp as we may need to send it over to our developers.
