We have the system tray configured for all of our policies, and our computers/servers are sorted into folders with the policy assigned to the specific folder, but the system tray isn’t showing.
Under Policies is the “Hide System Tray” Checked?
Check the effective policy on the assets.
If the Syncro System tary icon has disappeared, and the policy has not changed what is the solution to bring up the tray icon again?
Reboot didn’t fix the problem.
Not seen that issue. It does take a few minutes to show as the services are set to Automatic (delayed) by default. And of course it will be hidden in the overflow arrow menu by default. Have to drag it out or use the script in library while the user is logged in to pin it. Also tray icon only works for the first user that logs in, so no RDS server 4 you.
Thanks @isaacg
This is a Win 10 Pro laptop. HP Probook.
Syncro has been installed and the System tray working fine for 6 months.
AV is Webroot Endpoint Protection. Same as all the PCs we look after.
In parallel I’ve also logged a Support Ticket.
Same issue, I tried the script in the community area as well and it says program not found.
