Or well, I should clarify a bit. It can pass the ScreenConnect installer (in zip form) to the machine, but then you would manually install it, which is why it’s present in the app card. It’s not a full integration for Mac like it is for Windows though. Perhaps in the future, the Mac Agent just came out of beta so we’ve continued to expand the options it offers.
You can use ScreenConnect standalone if you wanted to.
We have tried this, but we are unable to find where it passes the file to. We have to download it manually and install it. Do you happen to know the file location that the zip goes to?
