Is there a way to rename a worksheet? Once a worksheet is created it cannot be renamed. Additionally when cloning a worksheet in Syncro you cant change it from the “Worksheet-Name(Duplicate1)” name that is auto populated.
There is, but this is one of the areas of Syncro where it doesn’t follow the rest of the UI guidelines more or less. so when you drill into any given Worksheet record, you’ll see the name and it looks like you can’t edit it. If you click it, though, it’s actually an inline field you can edit right there. This is a UI inconsistency we definitely need to clean up on our end.
Agreed. Thanks for the insight on this feature.
