This will walk you through connecting Syncro to QuickBooks Online (QBO).
Learn what is and isn't supported in QBO.
Note: You cannot integrate two separate Syncro Accounts into one QBO account.
- QBO Editions Supported
- Video Tutorial
- Get Connected to QBO
- How to navigate to QB Settings page
- Explanation of COGS (Cost of Goods Sold) Tracking
- Automatic Bill Creation in QBO when PO Status goes to Finished
- Automatically Sync Payments from QBO
- Invoice Payment settings sent to QBO
- Store Credit
- Converting from QuickBooks Desktop to QuickBooks Online
- Troubleshooting
Online Edition | Supported |
All QuickBooks Online Small Business editions | Yes |
QuickBooks Online Freelancer Self-Employed edition * | No |
* Because Syncro is designed to work with QuickBooks packages that include inventory management functionality.
Video Tutorial
- In Syncro, navigate to Admin > App Center.
- Find and click the QuickBooks app card.
- Click CONNECT TO QuickBooks.
- It will open a new window and have you login to Intuit if you are not logged in already.
- Next, it will ask you to Authorize Intuit to securely share your data. Click Connect.
Note: If your authorization doesn't go through, contact Intuit to fix your Intuit ID.
- After it securely transmits your data, the window will close and you'll be taken to the QuickBooks Settings Wizard. Click Start.
DO NOT SKIP ANY SETTINGS PAGES OR SYNC WILL NOT WORK
- "Map" all your tax rates to QuickBooks tax rates, then click Next.
- Map your 0% Tax Rate, then click Next. If you ever mark an invoice as non-tax for any reason, it will apply this "nontaxable rate" that you have set up in QB.
- In Syncro we allow "on the fly" invoice line items. Select what "fall back" item to attach them to in QB and click Next.
- Select the deposit account (almost always Undeposited Funds) and click Next. If you ever have an issue with payments syncing, this is probably what is not correct.
- Select your AP account where your purchase orders should go to (usually Accounts Payable). If your purchase orders don't sync it's probably because this important step was done incorrectly.
Also, note that when a purchase order syncs over to QB you must create the bill and pay it to receive the items in your inventory. Then you can go back and receive the items inside Syncro.
If you receive the items in Syncro first, it will close out the PO which means you will need to re-open it again to bill it. It is easy to miss a closed PO so be sure to bill it and receive it before closing it in Syncro to avoid discrepancies in your AP account and inventory.
- Map your payment methods to the QB payment methods and click Next. If these ever get out of sync due to changes on either side, payments will not sync over.
- If you want to Turn on Invoices/Payments/Customers Sync to QuickBooks, check that box. If you enable it, invoices will begin syncing after they are modified from now on (we don't sync historical invoices). If you leave it unchecked, the integration is turned off.
- You can also enable Sync all Syncro Products to QuickBooks if desired.
- Select the Income account for Sales of Products, Expense account for Cost of Goods Sold, and Inventory Asset Account as recommended.
- Click Next.
- We highly recommend on the next wizard step that you DO click Import QuickBooks Customers. This will ensure the ones that exist in QB will map to a Customer in Syncro. So the next invoice created for that customer will get sent to the right one.
Sub-customers note: Syncro does not have a concept of sub-customers, but QuickBooks does. This is handled between the two systems by Syncro treating sub-customers like "regular" customers.
When we import your customers, we'll try to import each sub-customer. If they all have the same email, they may attempt to update each other on the Syncro side. Give each a unique email one way or another in QB before importing for the smoothest import/setup.
- Same for products and vendors. The only reason to NOT import products would be if you have tons of products in QB that you don't want to use in Syncro. In that case, skip that step.
- Importing Vendors will pull in ALL your vendors into Syncro.
Product Types in QuickBooks
When your Syncro products are sent to QBO, they'll be sent as the following QB types.
- Inventory - if the Syncro item is set to maintain stock = true.
- Service - if the Syncro item is mapped to a "Service" item in QuickBooks. Items categorized as Labor in Syncro need to be mapped to items with the "Service" type or when they are created they need to be changed from "Non-inventory" to a "Service" type item.
- Non-Inventory - if the Syncro item is neither of the above.
How to Navigate to QB Settings page
Here are two ways to reach the QuickBooks Settings page whenever these instructions direct you there.
- In your browser's URL field, append /quickbooks/settings to your URL, such as
https://yourdomain.syncromsp.com/quickbooks/settings - Navigate there via Admin > App Center > QuickBooks Desktop/Online > Sync Settings
COGS (Cost of Goods Sold) Tracking Explanation
For the below steps to work, you will need a QBO Plus or Advanced plan, which includes inventory tracking.
A. Sync products in QBD and Syncro
- Create a new Inventory product in QBO or edit an existing one.
- Make sure the Income account is Sales of Product income, and the Expense account is Cost of Goods Sold.
- In Syncro, if you add the product, make sure you enter a Price Retail and Price cost.
- Navigate to your QB Settings page.
- Scroll to the bottom.
- If the product already exists in Syncro, click Check for Item Changes.
- If the product does not exist in Syncro, click Import Products from QuickBooks to Inventory.
NOTE ABOUT ITEM/PRODUCT IMPORTS:
The Product/Item imports include "Service, Non-Inventory Part, and Inventory Part” and exclude "Other Charge, Group, Subtotal, Discount, Payment, Sales Tax and Sales Tax Group"
B. Add item to invoice and sync to QBO
- Add the item to an invoice in your account.
- The invoice will sync to QBO.
- Accept payment on the invoice in your account.
C. View Cost of Goods Sold report
- To view the Cost of Goods Sold report in QBO, navigate to Accounting > Chart of Accounts.
- Search for Cost of Goods Sold.
- To its right, click Run report to see the Cost of Goods Sold report.
- To see your overall Profit and Loss Report, navigate to Reports > Profit and Loss.
- If COGS isn't showing up by default on your Profit and Loss Report, in the upper right under Accounting Method, click Accrual and then click Run report.
- Your Profit and Loss Report will look something like the one above.
- Head to the QB Settings.
- Check the Convert finished POs to Bills in QuickBooks box.
- Click Save QuickBooks Settings.
After that, whenever you set a PO to "Finished" Status, a Bill will be automatically created in QuickBooks so that you can pay your vendors.
Automatic Payment Sync from QBO to Syncro
It is possible to have payments created in QBO automatically sync to Syncro. To activate this feature,
- Head to the QB Settings page.
- Check the Sync Payments from QuickBooks box.
Once that setting is active the following behavior can be expected:
- You must create the invoice in Syncro and have it sync to QBO successfully.
- You can then capture a payment on the QBO side for that invoice and it will sync the next time the QBO sync job runs. This job only runs once a day in the early evening Pacific Time. It will sync payments created going back 24 hours.
Note: Applying multiple payments to an invoice in QBO will not sync to Syncro.
For those who want to take payments in QBO instead of Syncro, note the following.
When Syncro syncs an invoice to QBO, it includes the following settings in the sync.
- Allow Online Payment: False
- Allow Online Credit Card Payment: False
- Allow Online ACH Payment: False
The ramifications are, even if QBO is set to allow those things, invoices that come from Syncro will have them disabled. If you want to allow those online payments in QBO, you will need to manually edit manual and recurring invoices in QBO that came from Syncro to re-allow them. An easier solution is to take payments directly in Syncro, and then those payments will sync to QBO.
Store Credit
When a store credit is created it will become a credit memo inside your QuickBooks account. It does not get deposited into an account until it is applied to an invoice. Once the credit is added the credit memo will disappear.
If you're looking to convert from QuickBooks Desktop to QBO, please contact Syncro's support team at help@syncromsp.com. We support conversions when your QuickBooks Desktop company file is converted to QBO per Intuit's recommendations. There are also steps we need to handle on our end.
We're happy to help with this conversion -- just contact us help@syncromsp.com so we can help with planning the change.
Troubleshooting
If an Invoice/payment fails, you should see a red error appear on the Invoice or payment page with a message. This will often describe the error and give you first steps on what to look for. We have a glossary of Quickbooks API errors.
If you have a failed sync, in the upper right you can click Actions > Re-Sync to Quickbooks (or Re-Sync to Quickbooks or Re-Sync). Do this and wait a minute to see if the invoice/payment goes through.
Incorrect or missing QB ID error
Invoice: Actual QuickBooks Error: The following required ListIDs:
CustomerRef are blank.
This error indicates that the customer is not mapped to the corresponding customer inside QB. To clear this error, follow these steps.
- Navigate to the Customer's profile.
- In the upper right, click the book icon > View QB.
- You will be taken to a screen that displays the Syncro customer information and the QB counterpart's information if the customer has a QB id.
- In the upper right, click Re-Map.
- This will bring you to the Manually Map QuickBooks Customer screen.
- If needed, on the right, search for the correct customer. The names need to be an exact match for the system to locate the customer.
- In the search results at the bottom next to the correct customer, click Map to this.
Seriously use CAUTION here. If you aren't careful you can link customers to the wrong person, so if you are uncertain, please write support and we can help you. - Head back to the un-synced invoice.
- In the upper right, click Actions > Re-Sync to QuickBooks and you should be good to go!
Note that this will remap the customer, so if there are any additional invoices they will lose the sync ID and thus not have a sync icon.
