When using the following method to install the agent:-
syncro-installer.exe --customerid XXXXX
I get the following error. “Error trying to create device.”
Master Log
2021-11-18 01:35:05.524 +00:00 [INF] v1.0.144 (1) Starting Syncro Installer, version 1.0.144.0
2021-11-18 01:35:05.528 +00:00 [INF] v1.0.144 (1) Product: 'Syncro'
2021-11-18 01:35:05.530 +00:00 [INF] v1.0.144 (1) ImageName: 'C:\DirectIT\syncro-installer.exe'
2021-11-18 01:35:05.531 +00:00 [INF] v1.0.144 (1) Arguments: '"C:\DirectIT\syncro-installer.exe" --customerid XXXXXX'
2021-11-18 01:35:05.533 +00:00 [INF] v1.0.144 (1) OS Version: 'Microsoft Windows NT 10.0.22000.0'
2021-11-18 01:35:05.535 +00:00 [INF] v1.0.144 (1) OS Is64Bit: 'True' / 'True'
2021-11-18 01:35:05.536 +00:00 [INF] v1.0.144 (1) Interactive: 'True'
2021-11-18 01:35:05.538 +00:00 [INF] v1.0.144 (1) ConsoleMode: 'False'
2021-11-18 01:35:05.539 +00:00 [INF] v1.0.144 (1) AllowForceReboot: 'False'
2021-11-18 01:35:05.554 +00:00 [INF] v1.0.144 (1) Auth payload v0: False False False
2021-11-18 01:35:05.555 +00:00 [INF] v1.0.144 (1) Auth payload v1: True
2021-11-18 01:35:05.557 +00:00 [INF] v1.0.144 (1) .NET Framework 4.6.2 is already installed, proceeding...
2021-11-18 01:35:05.559 +00:00 [INF] v1.0.144 (1) Next stage installer: `Syncro.Installer.exe`, 'C:\Users\DouglasHall\AppData\Local\Temp\Syncro.Installer.exe'
2021-11-18 01:35:05.688 +00:00 [INF] v1.0.144 (1) Next stage installer is starting.
Installer Log:-
2021-11-18 13:35:06.285 +00:00 [WRN] v1.0.144 SOFTWARE\Wow6432Node\RepairTech\Syncro\ is null on HKEY_LOCAL_MACHINE
2021-11-18 13:35:06.318 +00:00 [WRN] v1.0.144 SOFTWARE\Wow6432Node\RepairTech\Kabuto\ is null on HKEY_LOCAL_MACHINE
2021-11-18 13:35:06.318 +00:00 [WRN] v1.0.144 SOFTWARE\Wow6432Node\RepairTech\Syncro\ is null on HKEY_LOCAL_MACHINE
2021-11-18 13:35:06.357 +00:00 [DBG] v1.0.144 Reading embedded config while using Newtonsoft.Json, ImageRuntimeVersion: v4.0.30319, AssemblyQualifiedName: Newtonsoft.Json.JsonConvert, Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed, GlobalAssemblyCache: false, Version: 12.0.0.0
2021-11-18 13:35:06.363 +00:00 [INF] v1.0.144 Loaded json string from resource Kabuto.Installer.config.json: {
"ApiUrl": "https://rmm.syncromsp.com",
"SyncroApiUrl": "https://admin.syncromsp.com",
"UpdateUrl": "https://production.kabutoservices.com/syncro/main/updates/"
2021-11-18 13:35:06.493 +00:00 [DBG] v1.0.144 ============================
2021-11-18 13:35:06.493 +00:00 [INF] v1.0.144 Starting KabutoInstaller v 1.0.144, args: '--customerid XXXXXX --jwt-payload ey***1Q'
2021-11-18 13:35:06.564 +00:00 [DBG] v1.0.144 Auth: jwt.Version = 1
2021-11-18 13:35:06.567 +00:00 [DBG] v1.0.144 Command args has been successfully parsed
2021-11-18 13:35:06.630 +00:00 [DBG] v1.0.144 Sending GET request to rmm.syncromsp.com:443/device_api/auth/, with null...
2021-11-18 13:35:07.396 +00:00 [DBG] v1.0.144 Got response from rmm.syncromsp.com:443/device_api/auth/, status "OK"
2021-11-18 13:35:07.398 +00:00 [DBG] v1.0.144 Cleanup unsuccessful install
2021-11-18 13:35:07.400 +00:00 [DBG] v1.0.144 Trying unregister service
2021-11-18 13:35:07.402 +00:00 [DBG] v1.0.144 Service not found
2021-11-18 13:35:07.402 +00:00 [DBG] v1.0.144 Killing Service.Runner
2021-11-18 13:35:07.407 +00:00 [DBG] v1.0.144 Killing App.Runner
2021-11-18 13:35:07.411 +00:00 [DBG] v1.0.144 Trying to clean registry, key: SOFTWARE\Wow6432Node\RepairTech\, subkey: Syncro
2021-11-18 13:35:07.411 +00:00 [DBG] v1.0.144 Trying to clean registry of installed program
2021-11-18 13:35:07.411 +00:00 [INF] v1.0.144 Cleanup unsuccessful install complete
2021-11-18 13:35:07.633 +00:00 [INF] v1.0.144 Downloading nuget package to `C:\Program Files\RepairTech`
2021-11-18 13:35:07.773 +00:00 [INF] v1.0.144 Downloading RELEASES file form `https://production.kabutoservices.com/syncro/main/updates/RELEASES` to `C:\Program Files\RepairTech\Syncro\packages\RELEASES`
2021-11-18 13:35:08.479 +00:00 [INF] v1.0.144 Downloading nugetpackage form `https://production.kabutoservices.com/syncro/main/updates/Kabuto-1.0.146-full.nupkg` to `C:\Program Files\RepairTech\Syncro\packages\Kabuto-1.0.146-full.nupkg`
2021-11-18 13:35:13.692 +00:00 [WRN] v1.0.144 key: SOFTWARE\Wow6432Node\RepairTech\ or value: computer_uuid null
2021-11-18 13:35:13.693 +00:00 [INF] v1.0.144 Retrieving effective device policy.
2021-11-18 13:35:14.151 +00:00 [ERR] v1.0.144 Error while CreateDevice
Flurl.Http.FlurlHttpException: Call failed with status code 422 (Unprocessable Entity): GET https://admin.syncromsp.com/api/syncro_device/installers/policy_id.json?customer_id=752052&folder_id=359749
at Flurl.Http.FlurlRequest.<HandleExceptionAsync>d__35.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Flurl.Http.FlurlRequest.<SendAsync>d__29.MoveNext()
at Flurl.Http.ResponseExtensions.<ReceiveJson>d__0`1.MoveNext()
at Kabuto.Tools.ConsoleAsyncUtils.<>c__DisplayClass0_0`1.<<ConsoleAwait>b__0>d.MoveNext() in C:\custombuilds\syncro\prod\master\Kabuto.Tools\ConsoleAsyncUtils.cs:line 0
