Hi.
Would it be possible to sign powershell scripts within Syncro? Im working with a customer that requires (GPO) scripts to be signed for them to be able to be executed.
Can Syncro hadle this in some way?
Hi.
You can sign them yourself, it’s just more code in the script. But any time you change the script you need to update the signing part.
Do you have an example of how to create a signed script in Synro?
It works the same way as it would with any PS script, Syncro doesn’t know anything about signing or care.
