Hello,
I’d like to know if there are any GPS tracking solutions that can be used alongside Syncro. I’m aware there are no integrated feature and the support said i can submit a feature request. But i’m curious if anyone using Syncro alongside some GPS tracking solution to tell us what they use and how good it is.
I use scalefusion in parallel with Syncro for device tracking, remote wipe, etc.
Thank you for sharing! i’ll look into it.
