Is there a way via saved search or some other method to find if a certain service is installed across all syncro devices?
I’m trying to audit which computers DO NOT have ThreatLocker installed and since it doesn’t install an app I’m having a hard time figuring out how to accomplish this search.
Thanks for the reply but like I mentioned ThreatLocker doesn’t install an application; only a service. So I need to query which devices do not have a specific service installed; not applications.
A service query would need to be done via scripting. From there, you can set a custom asset field based on that and then use saved asset searches with the custom asset field.
