This is my first time noticing anything wrong with patching. I have a system that I onboarded at 12:01 today. It is now 17:01 and my 3P Patch policy has not run.
I just checked that it is in the right policy folder and the right policy is applied. Still nothing. Is there a way to force it?
Did you reboot after you installed the agent? Open Background Tools and try choco /? and see if it comes back, if it says it’s not recognized, it needs a reboot.
I find it strange that if you install Choco outside of Syncro, you can use choco commands right away, but if it is installed through Syncro, it requires a reboot. I think that limits the automation of onboarding. I have my policy run at 10 to avoid it trying to update when the computer is in use, so I’ll have to wait to see what happens later.
Almost 24 hours later and still no 3rd party policy applied. I tried removing it from the policy folder and putting it back in last night and still noting this morning.
This is a little concerning. I am afraid that maybe 3PP is not working at all.
Where are the controls for 3PP? Reports? Ability to push the policy manually and check the logs?
