Where can I find my current Syncro subscription info?
If I add a subscription user, how does that work? When is the start-end date?
How do I know my current subscription term dates?
Go into Admin and click Account Profile > Choose Plan will show you what you currently have. If you go into Users and click add you will see: “Adding a user will adjust your pricing, a prorated invoice will be generated after any changes.” For actual past billing info you can go to SyncroMSP and create an account with the same email as your main Syncro account. For some reason there still is no link to this from the Syncro Dashboard after years of pointing this out.
Thanks isaacg, that was helpful.
