Splashtop Mac all permissions should not be required
We likely have vastly different end users. I’m guessing you’ve never have had a user ask you which button the space bar is either. :rofl:
MDM, yup. The entirety of this bug hinges on the fact that SyncroMSP’s Splashtop RMM fails with MDM configured clients. I run a macOS/Apple-shop and almost exclusively deploy DEP/ADE macOS devices and push the appropriate profiles to managed devices. There’s really no such thing as “Managing” macOS/iOS/iPadOS without an MDM. Like you, I am not dependent on SyncroMSP’s Splashtop RMM implementation, though I’d bet a fair number of Windows-first shops using Syncro are.
All that said the issue here is not what SyncroMSP can/can’t do. It’s what functionality the users of the product are paying for and the (lack of) responsiveness to a documented issue. If every InTune enrolled Windows Device needed a physical touch to enable Splashtop, I’m sure the issue would not be ignored.
So yes, I whole heartedly agree that understanding a platform’s limitations and using the right tool is “the way.” But accepting a bug and poor design because I can work around it, isn’t the way to help the platform grow, or at least come closer to meeting marketing promises of the platform.
Yes, the amount of time fixes have taken is concerning. There have been enough different people with different reasons or excuses now that I don’t believe the new CTO at face value. I don’t know what to really trust about Syncro anymore, which sucks.
I’ll also add that I have to use my MDM to restart the Syncro agent about 1x per week on my Mac machines. Do you run into this as well? I just opened a ticket and am going to send logs to Syncro support, but you’re much further down the road of Mac management than I am so I wondered if you saw this, too.
Hi Ed! Can I check how you do that? On a different issue than this topic, I’m seeing Syncro hang and stop processing scripts, usually when it’s doing its own sync. I’m hoping restarting it via MDM will fix the issue.
#!/bin/bash
sudo /usr/local/bin/syncro restart
Has anybody found a work around to this yet? We use JAMF School, and I can deploy the Splashtop streamer program to MACs, and the MACs show it’s installed. However, it gives a similar error to what’s posted above when it tries to enable itself.
It’s all the MAC permissions that are required that are the issue as stated above.
-How’s about an apple configurator package that goes through these steps when deployed?
-or a script that runs when splash top is being deployed through JAMF (or any other MDM). Or has there been any updates?
Thanks!
Hi. No workaround yet. I have been trying to deploy Syncro via Miradore on MacOS. Whilst the install itself s fine, I have been seriously struggling with pre-deploying PPPC settings using PPPC Utility. The PPPC controls for Syncro and Splashtop are deployed and visible within Device Managementr, but you cannot remote onto the Mac, no matter what you do; typical error is “Cannot Sync”. When I remove the PPPC profile using Miradore MDM, I can reset the permisssions manually…and hey presto, Splashtop for RMM works. The solution is simply to silently install Syncro which can then push Splashtop for RMM, but do not use MDM to push out your PPPC settings for Syncro OR Splashtop. A hard lesson, and 10 hours lost, but I have accepted that Apple have this requirement and that I will have to give my users the local password if remotely configuring a machine. Of course I can then change it, but what a ruddy palava!
