I would like my users be able to send a ticket in with a subject “Restart …” After this ticket is received, I would like an autoremediation to fire off a script
I don’t think that’s currently possible. You can set specific scripts to be available for users to run from their Portal though.
I came up with a crude workaround for this. You can raise an alert against the asset and have this run an auto remediation.
To generate an alert I created a PS script placed on the desktop,
You could also create a Powershell script and run it on an app server (if you have one) every few minutes and call the API, looking for tickets with a given subject then do whatever you want after that, ie. trigger an alert (which triggers automated remediation script), trigger email, etc…
You could add that to the tray as a cmd so the user just needs to click that option to restart the pc.
