Power User List of Useful MacOS Community Library Scripts
The MacOS scripts often are an afterthought, even if most IT Teams have to support ATLEAST one Mac Endpoint. Syncro does have full Support for using the same commands as available in PowerShell, as well as scripting variables. Since they are often hard to find in the Community Library, I looked through all the scripts and compiled a list of all the MacOS specific ones I could find. I might have missed a few. If I did, let me know and I can update this list.
Additionally, I will be adding two new ones to assist with Splashtop Streamer Install / Uninstall on MacOS Troubleshooting.
MAC - Splashtop Streamer One Time Install Push for MAC
MAC - Uninstall Splashtop Streamer - Requires User Interaction
I would love to see more Mac Scripts submissions to the Library, especially if they utilize the Syncro commands or variables!
In ABC order, thanks to everyone who contributed so far: David Geiger, Eddie Rivera, Erick Grau, Erik Ryan Sanchez, Fernand Jonker, Jason Phelps, John Kennedy, Jonathan Baynes, Jordan Albaladejo, Kelvin Tegelaar, Richard Burt, Scott Pettie, Steven Grabowski
Shorter List - General Use Focus
CyberDrain.com - Mac OneDrive Reset
MAC - Check FileVault Status
MAC - Disable Remote Access
MAC - Enable Firewall
MAC - Flush DNS
MAC - Get FileVault Drive Encryption Status
MAC - Purge Disk Cache
MAC - SSH Disable
MAC - SSH Enable
MAC - Time Machine Config + Enable + Backup
MAC - Warn User + Purge DNS + Purge Disk Cache
MacOS - Last 24 hours - Last Login Failure found
Updates for Mac environment - Silent w. Reboot
All MacOS Scripts List
Huntress Deployment (macOS Agent)
MAC - Ask Bitdefender to do a Full Scan (Needs authToken)
MAC - Ask Bitdefender to do a QuickScan (Needs authToken)
MAC - Ask For Bitdefender Status (needs authToken)
MAC - Enable Gatekeeper
MAC - Flush DNS
MAC - Jumpcloud
MAC - Kill_Restart CoreAudio
MAC - Reapply User Permissions
MAC - Remove AnyDesk
MAC - Remove Webroot
MAC - Reset Launcher Service
Mac - Restart Splashtop Service
MAC - SSH Disable
MAC - SSH Enable
MAC - Time Machine Backup STATUS in %
MAC- Block Catalina Update
macOS - Install Watchman Monitoring Default Group SyncroMSP
MacOS 10.15 Catalina - Block Auto-Update
MacOS 10.15 Catalina - Re-enable Auto-Update
Splashtop Set User to NOT Prompt MAC
5
This is awesome! And once again, thank you so much to everyone who’s contributed to the community script library :clap:
These Community Scripts really need to be audited for functionality and best practice.
MAC - Time Machine Config + Enable + Backup - AFP is deprecated
MAC - Warn User + Purge DNS + Purge Disk Cache - not current method to flush DNS
Updates for Mac environment - Silent w. Reboot - Just no. By 10.15 ‘softwareupdate’ could barely pull off an update as scrpited here. Everything changes with macOS 11, volume owners etc.
MAC - Reapply User Permissions: depricated as of 10.11 (released 10 years ago today)
MAC - Reset Launcher Service: ‘-kill’ has been depricated and removed from the command.
MAC- Block Catalina Update , MacOS 10.15 Catalina - Block Auto-Update, and MacOS 10.15 Catalina - Re-enable Auto-Update - this method of blocking updates does not work currently and blocking macOS 15 is at best an edge case
Are these scripts the ones you submitted?
I can remove / delete them, and you can update and resubmit the same one. Once I delete it, it allows for you to resubmit. Or You can submit new ones and let me know. I usually review and approval community scripts at the end of the month, so this was a great reminder
These are non-functional in modern macOS and should just be deleted.
I have no need for the other script functions, but asking Claude or GPT for a bit of guidance and some hands-on testing could be a good way to go.
Any chance you can create a blocking script for mass storage devices via USB?
While still allowing peripherals such as mouse and keyboard to work.
I’ll preface this by saying my macOS experience is limited. After some research time, this doesn't not look particularly easy, and possible quite difficult for Macs. I keep getting directed to use MDM type tools to set this, since Apple does not have a native way to do this via a BASH Script. There are some free MDMs out there, like Mosyle but I personally have little experience, so I am unsure how easy this is to configure.
