This MAV product gives you the awesome power of Webroot at your fingertips for an amazing price.
Webroot is $1 per endpoint.
What the integration does
- Allows you to create a new Webroot account to use with Syncro
- Allows you to migrate your existing account to be managed by Syncro
Create a new Webroot account
Apply Webroot to a Policy
Migrate an Existing Webroot account
Billing
DNS Protection
FAQ
Create a New Webroot Account
If you have already have a Webroot account, see how to migrate an existing account.
- Navigate to Admin > App Center.
- Find and click the Webroot app card.
- Fill in all the data.
Make sure to capitalize the state/province letters or else it will not work.
- After you fill out the form, click Create new Webroot Account.
- An email from Webroot will be sent to the email that was used when signing up on the app card. You should receive the email shortly (at most 10 minutes). Follow the instructions in the email to sign in to your new Webroot account (SecureAnywhere).
- When prompted to select which kind of organization, under Managed Service Provider, click Select.
- Return to Syncro and click I have signed into my new Webroot Account to continue the configuration.
- Next, click Grant SyncroMSP Access to my Webroot Account to do that.
- This will send you an email from Webroot asking you to confirm our request to become an API admin on your Webroot account. Follow the link in the email to confirm access.
- After confirming access, return to the Syncro app card and click Verify Syncro has access to my Webroot Account. Or, if you did not receive the email, click the Retry button at the bottom.
- Webroot is now available to use. Click the Policies link to add Webroot to them.
- Head to the Policies page.
- Click a policy you wish to enable Webroot on.
- In the left navigation, click Antivirus.
- If you do not see the Webroot module, click Select > Webroot.
- If you have migrated from another account, you will see the below section. You can either leave the first dropdown (A) set to Syncro Managed, or change it to Webroot Managed.
- If this was a Syncro provisioned account, you should see the below section instead.
- In either case, in the Webroot Policy (Global Only) dropdown (B), select the desired policy.
- Click Sync Webroot Policies (C).
- In the upper right, click Save Policy and Webroot will now be applied to all assets on your policy.
Migrate an Existing Webroot Account
If you already have an existing Webroot account, you can migrate the account to be managed by Syncro. To get started, head to the App Center and select the Webroot App Card.
- Click the here link to be taken to the migration wizard.
- Click Continue to start the migration.
- Next, you will need to get enter your Parent GSM Console Key to continue (this can be found by navigating to your Webroot console, then heading to Settings - Account information - Parent keycode):
- Webroot requires some customer information in order to take over your account from your current provider and process billing. Please use the Webroot GSM Admin email from your account. All Webroot related emails will continue to go to this email address. Once all the information has been entered, select 'Continue'.
Webroot requires some manual work to perform an account migration. They need your express written consent that you wish to migrate your account to be managed by Syncro, which we will pass along on your behalf. To begin we will need you to send an email to us at webroot-migrations@syncromsp.com.
It is important to use the GSM Admin Email and not a user email if there are multiple emails. Also include your Name, Company Name, and Keycode which are associated with the account as well.
Once we receive this email, we will send it over to Webroot. Webroot will verify your account credentials (email, keycode, and name) are an existing Webroot account. If so they will transfer your account at the end of your current billing period.
Depending on your current Webroot account setup, your current billing period could end at the end of the month or as much as a year from now.
Please Note: If your Webroot billing period does not end within 90 days from the migration request, you will need to wait and re-request once you are within 90 days of the billing period. If this is the case with your Webroot account, we will notify you and tell you when you can make the migration request again.Now, if the billing period does end within 90 days of your migration request, Webroot will migrate your account on the date your billing period ends.
The migration will be paused until your migration time seen on this page has occurred. Once that date has passed and your account has been migrated to us, you can continue with the migration wizard onto step 5. - Next, Syncro needs to request admin access to your Webroot account. This will allow us to access your Webroot data via API. Hit 'Continue' to have Webroot send you an email to confirm this request.
- You should now have received a confirmation email from Webroot to approve SyncroMSP as an API admin on your account. Once you have this approved, 'Continue' to the next step.
- Next, we want to make sure that the Syncro agent is installed on all the computers that are listed in Webroot to ensure the migration runs smoothly. If the agent is not installed on any devices, you can leave this step to install and come back.
If there are any missing agents or this step is skipped, you may end up with some devices in Webroot that Syncro does not manage until the mapping is fixed later on.
- Now we have collected all of your Webroot Sites. If there are any Sites missing, click the 'Re-sync Webroot Sites' button. You are also given the option to change the Syncro customer that was mapped or select a group of sites to create new Syncro customers.
Select 'Continue' to move on to the next step. - Next, we will handle any discrepancies between Assets, Webroot Endpoints, Webroot Sites, and Syncro Customers.
It is possible that a Webroot endpoint is on a different Webroot site than the Syncro customer. In this case, for any mismatched asset we can perform the following actions:
1. Move the asset to the Syncro customer that the Webroot endpoint it is mapped to
2. Move Webroot endpoint to Webroot Site that the Syncro customer is mapped to
3. Create a new Webroot site on the Syncro customer and move the Webroot endpoint to
You can modify assets with the above options here:
Or you can modify assets individually here:
Note: Options will be available given the current state of the asset. So, some assets could have options 1 and 3 available while others have 1 or 2.
Once all assets have been modified, select 'Continue' to move on to the next step. - The next step in the integration is to set up your Syncro policies with Webroot. Syncro Policies can interact with Webroot by being Syncro Managed or Webroot Managed.
Syncro Managed
A Syncro Managed policy enforces the Webroot policy to a Syncro policy on all connected assets. It also enforces the Webroot Site to the connected Syncro customer on all connected assets.
If Webroot is already installed on the asset but is not managed by Syncro, we will re-install Webroot to ensure we are managing it.
If the asset is moved to a Syncro policy without Webroot, Syncro will uninstall Webroot.
If the asset is deleted in Syncro, Webroot will be uninstalled.
Webroot Managed
If Webroot is already installed on the asset, Syncro will not do anything. If Webroot is not installed on the asset, Syncro will install Webroot using the Webroot policy on the Syncro Policy.
For new assets, Syncro will use the Webroot site that is connected to the Syncro customer. We do not enforce it though, so this could be changed in Webroot.
Once the policies have been set up, confirm your policies to continue:
- The final step is to confirm your Webroot settings in order for the integration to go live. Nothing will go live on your assets or policies until you select the 'Finish Wizard and Enable Webroot on Policies' button below:
Billing
- You can review your MAV billing and license usage anytime using our Managed Antivirus Usage Report by heading to Reports > RMM > Managed Anti-Virus Summary
- The Syncro billing system will send an automated email 5 days prior to your subscription renewal with your anticipated MAV charges
- Webroot asks that all billing or tech support questions/concerns be directed to them at 1-866-254-8400
DNS Protection
You can enable DNS Protection in the SecureAnywhere portal. The cost is an $1 per endpoint. Syncro will bill you for it. So if you get their antivirus protection as well, that is a total of $2 per endpoint.
FAQ
Why is my Webroot install still 'Pending'?
Have you cleared off the system of competitor AVs and previous installations of Webroot? This can and will prevent Webroot from installing. If there are residual files or registry keys left over from an improper install this can also be a cause. The AV may offer an uninstall cleanup tool on their website.
Have you allowed time for a sync? Please allow for a couple of hours for our sync that manages Webroot. If you are still waiting, please contact support.
I just migrated to Syncro, but my Webroot sites are expired!
This happens on the backend of Webroot. Please let us know and we can request Webroot push a resync. You can request this from Webroot on your end as well.
How often does the system check for devices that need Webroot installed?
The system will check every 15 minutes.
How do I remove WebRoot agents?
To remove the Syncro deployed WebRoot agents simply remove Webroot for the assigned Policy. To ensure your licenses are deactivated and won't incur further charges make sure those assets are also removed from SecureAnywhere. You can find current Webroot assets here: https://usage.webroot.com/login.
