I just started using the speed test script in the library but its showing wrong and much lower speed numbers from the script than if I just went to the speedtest.net site. For example, on my workstation, it shows 92.06 download through the script and direct from speedtest.net 925. download which is more accurate. Anything I’m missing ?
Hi @bob
Could you send us more details by creating a Support ticket? We would need the asset you saw this on as well as a link to the script.
Here is my working script. This downloads the Ookla command line tool and uploads a result report to the asset.
# Speedtest script cobbled together mainly from the Ookla site.
# Speedtest script cobbled together from several resources mainly the Ookla site.
# Gary Herbstman, Byte Solutions
To get the latest download URL go to https://www.speedtest.net/apps/cli
Update the $URL variable below.
Speedtest by Ookla is the official command line client for testing the speed and performance of your internet connection.
Version: speedtest 1.0.0.2
Usage: speedtest [<options>]
-h, --help Print usage information
-V, --version Print version number
-L, --servers List nearest servers
-s, --server-id=# Specify a server from the server list using its id
-I, --interface=ARG Attempt to bind to the specified interface when connecting to servers
-i, --ip=ARG Attempt to bind to the specified IP address when connecting to servers
-o, --host=ARG Specify a server, from the server list, using its host's fully qualified domain name
-p, --progress=yes|no Enable or disable progress bar (Note: only available for 'human-readable'
or 'json' and defaults to yes when interactive)
-P, --precision=# Number of decimals to use (0-8, default=2)
-f, --format=ARG Output format (see below for valid formats)
-u, --unit[=ARG] Output unit for displaying speeds (Note: this is only applicable
for human-readable output format and the default unit is Mbps)
-a Shortcut for [-u auto-decimal-bits]
-A Shortcut for [-u auto-decimal-bytes]
-b Shortcut for [-u auto-binary-bits]
-B Shortcut for [-u auto-binary-bytes]
--selection-details Show server selection details
-v Logging verbosity. Specify multiple times for higher verbosity
--output-header Show output header for CSV and TSV formats
Valid output formats: human-readable (default), csv, tsv, json, jsonl, json-pretty
Machine readable formats (csv, tsv, json, jsonl, json-pretty) use bytes as the unit of measure with max precision
Valid units for [-u] flag:
Decimal prefix, bits per second: bps, kbps, Mbps, Gbps
Decimal prefix, bytes per second: B/s, kB/s, MB/s, GB/s
Binary prefix, bits per second: kibps, Mibps, Gibps
Binary prefix, bytes per second: kiB/s, MiB/s, GiB/s
Auto-scaled prefix: auto-binary-bits, auto-binary-bytes, auto-decimal-bits, auto-decimal-bytes
# $URL = "https://install.speedtest.net/app/cli/ookla-speedtest-1.0.0-win64.zip"
$URL = "https://install.speedtest.net/app/cli/ookla-speedtest-1.1.1-win64.zip"
$zipFile = "$env:TEMP\speedtest.zip"
$exeFile = "$env:TEMP\speedtest.exe"
$mdFile = "$env:TEMP\speedtest.md"
$resultFilePath = $env:temp + "\" + "Speedtest_" + $(get-date -f yyyy-MM-dd) + ".log"
$exeParams = "--accept-license --progress=no -v"
$ProgressPreference = 'SilentlyContinue'
Invoke-WebRequest -Uri $URL -OutFile $zipFile -Headers @{"Cache-Control"="no-cache"}
Expand-Archive -Path $zipFile -DestinationPath "$env:TEMP\" -Force
# Runs Speedtest and outputs to a text file
Start-Process -FilePath $exeFile -ArgumentList $exeParams -Wait -RedirectStandardOutput $resultFilePath -WindowStyle Hidden
Get-Content $resultFilePath
# updload results to Syncro asset
Upload-File -FilePath $resultFilePath
Remove-Item -Path $resultFilePath -Force
# Remove left over files from program
Remove-Item -Path $zipFile -Force
Remove-Item -Path $exeFile -Force
Remove-Item -Path $mdFile -Force
Thanks this works for me appreciate it !!
You’re welcome Bob. And a few more characters so I can post this reply.
