McAfee Removal Tool Fully Silent? - MCPR.exe
Does anyone have a script to run this silently by chance please? I’m useless with scripts and I can’t seem to find a way to get around the limitations of the below article.
It says you have to start the application and “hold it open”, but this seems only possible with Intune so a full silent Syncro script uninstall would be great as tons of our new PC purchases have this software on it which stops Bitdefender completely.
Thank you in advance for your help!
Regards,
Mike
If you have 7zip installed you can just extract the tool. If I have time, I will build out a script.
7z e mcpr.exe mccleanup.exe -r
Actually just extract the mccleanup.exe tool and upload it to Syncro and just run the script in the link above.
Thanks Jeff, my scripting guru is on Long Service Leave, I’m struggling without him, so glad we have a great community here to help out!
Warm regards, Mike
I made some good progress on a McAfee uninstall script. I will share after a bit more testing.
Syncro question here, why does:
Get-apppackage -Name "*mcafee*" | Remove-AppPackage
or
Get-apppackage -AllUsers -Name "*mcafee*" | Remove-AppPackage
Work from a Powershell Admin prompt, but not from a script?
We are about 95% functional here on McAfee Personal v2.13 that was bundled on an Alienware Win 10 Pro box I had sitting here. It appears to remove everything including 2 of the entries in the installed Apps. The remnant in the Apps section that is still there goes away with the Remove-AppPackage from the command line. I am still working on why the script doesn’t get it. But the rest of the code is working and McAfee does not seem to be registered as an active AV in Windows or Syncro.
I still need to test out the Choco side of installing 7-Zip. On a new machine where Syncro has not done any Third Party Patch Managment there is just no Kabuto package manager aka Choco installed yet. I foresee that will become a bigger routine that I will also include with the manual choco script that was talked about in another thread recently.
So still a work in progress but functional enough if needed today.
Hi Jeff,
Terribly late I know, only over a year but haven’t been using Syncro as much and not using the forums. I just want to express my (super belated) gratitude for this. Thank you.
Just an FYI, you’ll need an old version of MCPR for this to work. The current one no longer supports silent command line functionality. I imagine sooner or later the old version will stop being effective on current McAfee installs. 10.3.145.0 from 2021 is one I know that works, there may be a newer version.
Does someone have the old MCPR file link?
https://filebin.net/goj7dplowm90urz9 is what i have from 2021. There may be something slightly newer, not sure. I don’t know if it works anymore or if it does how well, so use at your own risk/YMMV.
Here is what I had on file dated Feb 2022 v10.4 so should be just barely newer than Isaac’s version. Use at your own risk. This file is from my personal archives. Not something pulled recently.
Added-I had to ZIP. This site won’t take raw exe files.
