Access these via Admin > Leads - Preferences.
Enable Leads Module: Allows you and your team to use the Leads Module.
Enable Lead Auto response Email: When a Lead is generated a automatic response will be sent back to the customer. You can edit the template by navigating to Admin > PDF/Email Templates > Lead Auto Response.
Leads converting to Ticket should trigger Print Jobs: When enabled will send a print job when a Lead is converted to a ticket.
Parse SUBJECT of inbound leads emails for phone numbers (can cause imperfect matching): This will force the Leads module to try and match a phone number from the inbound email subject
Parse BODY of inbound leads emails for phone numbers (can cause imperfect matching): This will force the Leads module to try and match a phone number from the inbound email body
Lead Notification Email Address: This email will be alerted when a new lead is generated.
