Our app allows you to modify the tabs that display across the top for a more customizable experience.
- In the upper right, click your name > Tabs Customization.
Once there, you can turn on the checkboxes next to all of the tabs that you want to display across the top of the page. You can also re-order the tabs by dragging the three horizontal lines to organize the tabs in any order you wish. The tabs going top to bottom will display left to right.
After making any changes, make sure to scroll to the bottom and click Save.
What's nice is that this is a per user setting. So you can have a different tab layout than other users in your organization. Customizations are stored server-side, so they will follow you to different browsers, sessions, and computers.
Please keep in mind that if you have more tabs enabled than will fit across the top, a More tab will appear in place of the last tab and will have the rest of the tabs that couldn't fit listed underneath it, like so:
Clicking Reset to defaults at the bottom and then Save will revert your tabs back to the application's original state.
