What It Does
Grabs Customer, Contact, and Asset info and brings them in to Hudu.
Create Hudu API token
You will need to create a Hudu API token.
- Navigate to Admin > API - API Tokens (at the bottom).
- In the upper right, click New Token.
- To the right of Hudu, click Create Token.
- In the dialog that appears, click Create API Token.
- Once the New Hudu API Token Created screen appears, copy the API token that appears. You will paste within the Hudu app.
Use the key in Hudu
To continue from here, read Hudu's Setting up the Syncro Integration article. You can skip the "Permissions needed from Syncro" section since the above steps cover that.
