Customer Tags are an easy and flexible way for you to categorize your customers beyond the filtration methods we already offer, to help empower you to develop more dynamic ticket automations and robust filtering for your customer saved searches.
- Customer Tag Security Permissions
- Customer Tags Overview
- Creating Customer Tags
- Deleting Customer Tags
- Tags in Customer Create and Edit
- Tags in Customer Detail
- Customer Tags in Bulk Customer Actions
- Customer Tags in Customer Saved Search
- Default Technician Assignment Using Customer Tags and Real Time Automation
- Leveraging Customer Tags to flag VIP customers and driving automations
We have added 3 new Security Permissions to Admin > Security Groups. These permissions will be inactive by default and will require an Admin to activate them for the Security Group.
Customer Tags - Create
- Allows you to create new Tags
Customer Tags - Delete
- Allows you to Delete Tags
Customer Tags - View
- Allows you to see Customer Tags in the various places of the app
Customer Tags do not need to be created in the Admin settings before using them on customers.
To create a new tag, you can simply begin typing the tag in the input field and click the âEnterâ key or select the option to â+ Createâ the new tag in the drop down.
For example, on the Customer Detail page in the left-side Overview section:
Youâll also notice that when you click into the field and begin to type, you will see two sections - Recent Tags and All Tags.
Recent Tags - Your most recently used Customer Tags, scoped to your user activity.
All Tags - This is a list of tags based on matching the text entered in the search. All customer tags include any tag associated with at least one customer on your account.
NOTE: Tags are designed for internal use. Your customers cannot see the tags you create.
To delete a tag, simply click into the Customer Tag input area and select the âXâ to the right of the individual tag. Alternatively, you can click the 'Xâ at the upper right of the field to clear all tags on the Customer.
When a tag no longer exists on any Customers on the account, the tag is deleted and will no longer show up in your âRecentâ or âAllâ tags.
Tags cannot be reinstated once deleted, they must be recreated and added to at least one customer.
A new Tags section has been added to the Customer Create and Edit pages.
When creating a new customer, any Tags added in the Tags field will automatically be associated with the customer after they are created and can be visible from the Customer Detail page.
If you have the correct corresponding Security Permissions then you will see a Tags field in the Overview section of the Customer Detail. It has the same functionality as the Customer Create and Edit page.
You can search for Tags in this field. The same âselectâ and âcreateâ methods apply as described in the Customer Create section.
Weâve added the ability to edit tags in bulk from the main customer index. Simply select at least one customer using the multi-select option on the index page and select âBulk Actionsâ in the upper-right of the index page to manage them.
Current Tags in Customers: This field will populate all tags associated with the customers you bulk selected. From this field, you can remove any of the tags youâd like.
Given the âCurrent Tagsâ field is an accumulation of tags across many customers, when deleting a tag from this field, weâll only delete the tag on customers where the tag is associated with them. Weâll skip any customers where the tag isnât associated.
Add New Tags to Customers: Entering tags into this field will add this tag to all of the bulk selected customers after selecting âUpdate Recordsâ.
If the tag youâve entered is already associated with one of the customers youâve selected, then weâll simply skip this when bulk applying the tags.
Given we allow up to a maximum 50 tags on a customer, if one of the bulk selected customers already has a maximum 50 tags associated with it, then weâll skip adding this tag to the customer when performing the bulk action.
Weâve added the options âCustomer Tags Includesâ and âCustomer Tags Excludesâ to Customer Saved Search. So, you can easily filter your main customer list based on tags you assign to your customers.
In conjunction with our new Real Time Automation trigger âTicket Createdâ, Customer Tags are a great way to create automation rules that automatically assign new tickets submitted by customers to dedicated technicians.
Say you have a large client that you want to ensure is taken care of by one of your top technicians whenever they run into an issue. Whenever this client submits a new ticket, we want to ensure that our top technician Frances is assigned to their ticket.
As a first step, weâll add a Customer Tag to the customer record for Artest Industries called âfrancis accountâ:
Now, weâre going to create a corresponding Real Time Automation rule that automatically looks for the âfrancis accountâ tag on customers submitting tickets.
So, weâll create a condition in the automation âCustomer Tagsâ > âIncludesâ > âfrancis accountâ. Then, weâll create an action in the automation rule that assigns tickets that match this condition to our technician Frances:
Now, when the example client Artest Industries submits a ticket, or for any of our other clients with that âfrancis accountâ customer tag, these tickets will automatically be assigned to Francis moving forward without the need of manual assignment.
Note: While in this example we used the tag, âfrancis accountâ, this flow is completely flexible and you can use any tag naming convention youâd like so long as the customer tag name is referenced in the automation as it appears on your customer records.
Similar to the example above, say you wanted to flag your VIP clients to ensure any tickets they submit generate internal team alerts and are assigned to a dedicated ticket board for triaging incoming VIP issues. To get started, we can introduce a âvipâ tag on our largest clients using customer tags.
Now, with this tag associated with our VIP client, we can create an automation rule that looks for this customer tag when clientâs submit tickets. In our automation actions, weâll make sure the ticket gets tagged âvip queueâ and weâll also generate an alert in our Microsoft Teams account to ensure our team is notified that a new VIP ticket has been submitted:
Lastly, weâll want to ensure that we have a dedicated ticket view configured for our Vip Queue. The view looks for any ticket with the tag âvip queueâ associated with it:
Now, anytime our VIP customer submits a ticket, our team will automatically be notified in our Microsoft Teams account and the ticket will post in our dedicated VIP queue:
