What it Does
- Matches Syncro companies to Cloudradial companies
- Syncs contacts between Syncro and Cloudradial
- Updates Syncro contacts from Office 365
- API submission of tickets
- Ticket viewing and searching
- Ticket updates with feedback
- User notes viewing
- User file upload
- Invoice viewing and the ability to open into Syncro portal
Getting Started
The Cloudradial Team made an awesome KB to get things going, Setting Up the Syncro/Repairshopr API Integration with CloudRadial.
What You Will Need
The integration makes use of API Tokens in Syncro.
