Does anyone track warranty labor hours in Syncro?
How do you do this?
Sort of, we have a work type of warranty we use. Reporting on different types of labor is hard enough to get we haven’t actually been watching hours spent, but the log is the if we ever want to uncover it.
In Syncro just use labor types. We just use one for all warranty but you can create as many as you need.
Each work type has a default rate, and can be overridden in contracts. This would apply less to warranty but if you have a std biking rate, and need to discount it for a long-term contract or set to $0 for an AYCE contract you can.
I guess using additional work types would be kind of ok. Though is far from ideal compared to the flexibility we are used to
