Transfer between syncro agents
Hi there, I am migrating a couple assets to my syncro account, however they are already running syncro from another MSP.
Has anyone installed the new agent and uninstalled the old one via Powershell successfully?
Hi @matticem - We recommend running the agent uninstaller tool, restarting the machine then you can install the new agent.
KB: Install a Syncro Agent on a Device
Thank you. So it seems I won’t be able to do it remotely in this case.
