Temperature monitors
Is there a way to monitor temperatures of devices, such as CPU temp, Hard drive temp using Syncro?
native monitors no,
this is the kind of thing people would use a script and possibly a third party cmdline utility to monitor.
No, but sure would be nice if it was native. I believe there’s a lost in the feature request section about this. You should go heart the post to give it your vote.
Would you see this as a valuable feature with just the threshold monitoring that Syncro has already, or would you need to be able to see history for this to be valuable?
In other words, are you trying to catch the one time the device gets to hot so you can respond to the alert and save the day, or are you looking for poorly ventilated or over worked machines with a history of running a bit to warm?
Looking for a threshold to alert monitor. Not really interested in historical data.
Check out TempProber in the community scripts. Haven’t tried it yet YMMV
CPU temperature is actually visible under system info in Syncro Live. Wish there was a way to pull that number and make it a monitor in the RMM.
