System monitors / System checks
It would be nice to have a way to quickly see all the monitors (i.e. custom process, service, or event viewer monitors) applied to a device under one tab.
Also, “Monitoring” and “System checks” should be merged into one tab.
Additionally, please add the options to apply a service, process, and event viewer monitor template per device under the “System Checks” tab.
Additionally, I would request to add the option of monitoring in Syncro for
-custom asset field
-If applications exist or not.
-File folders.
-Register key.
-script monitor.
And apply action based on the above monitor results.
If anything requested is already available, please let me know.
Thanks.
I’m totally onboard with your suggestions. Thank you.
