Is the default Syncro reboot command available to use as a script? I like the simple design and functionality. I’m surprised to see there isn’t a default reboot available to be scheduled on assets.
That’s a special internal script so it’s not. That said, you can easily create one. Reboots are basically one liners in batch and powershell.
BATCH
shutdown –r
POWERSHELL
Restart-Computer
Just note that in many cases you may want to add a delay to the reboot command, as instant reboots might occur before the script has the chance to send the results back to the web to show completion.
Yeah no problem at all :).
You may want to use /g for a ‘gentle’ restart instead of /r (reopens apps) and /f for forcing if you mean business.
Thanks, I wasn’t aware of /g. I’ll have to test that on some Dentrix systems to see if it will restart them instead of /f.
You can use /f still, it just forces apps to close even if they don’t want to. Which can potentially lose data but otherwise the system will just wait for the user to close the app gracefully/save their files
Our solution was to use PowerShell to create a scheduled task–much more flexible.
