Splashtop UUID
The Splashtop UUID suddenly appeared as a populated field under custom fields on the Asset pages.
Should I be concerned?
Are you using your own ST account that you’ve linked to Datto? If so the UUID is just a field that shows the unique ID for that Splashtop install. Nothing to be concerned with.
