Hi,
Since last week I’ve been having this issue that Splashtop is not showing correctly, the screen looks out of sync on the first top half and blacked out on the bottom one.
Anyone having this problem as well?
Thanks.
Hi,
Thanks.
Not having that issue at the moment, nor ever seen Splashtop do anything like that.
Have you tried launching Splashtop from a different computer ?
Started to happen in several machines, it was working fine until mid last week.
I just found what the problem is, it was an update from my onboard graphics card that’s causing the issue.
Hi,
The problem is back and it doesn’t look related to the graphics card driver, still have the one that I rolled back.
Any one having the same issue?
Thanks.
