Is there a way to sort the saved searches I have created alphabetically rather than last creation date?
Hello- when viewing your saved searches they do appear in alphabetical order when I look at them. Do you have a screenshot of what you see?
Actually it looks like the right menu is reverse alphabetical and the left menu is alphabetical.
Yep, this is the case. If you click the magnifier that’ll bring up the alphabetical list. Otherwise there isn’t a way to reorder the one on the right.
Have you filed a bug for this? The behavior should be the same as the left.
How does one do that? I am new to the product.
I can get one started for you no worries- if you need to submit one in the future you can email help@syncromsp.com
