Show PC Startup Programs
Hi.
Q. Is there a script or menu which shows which programs are running on PC start-up, or even better, with the option to disable or delete them please?
Similar to that within ccleaner.
Regards.
Try this in powershell.
Get-CimInstance Win32_StartupCommand | Select-Object Name, command, Location, User | Format-List
It would be awesome to have the output in the SyncroMSP WebUI, but we might be waiting a lifetime squared for that.
Hay ho. Thanks for the reply.
Regards :+1:
