SentinelOne Installer/Or Similar
We have installers for SentinelOne 32-Bit and 64-Bit. We have a script to install but wanted to see if the variable could automatically pull from a custom field for each client. Is this something that’s possible?
Yes it is…see this article: Syncro Scripting
thi is never something we have managed to get working. We are havving to install S1 manually
Allan, we ended up uploading the most recent exe installers for 32 and 64 bit to the portal. Then we created a custom field for each client where we would put their Sentinel key. Once this was done, we scripted the following:
C:\temp\S1Agent_v2212217-32.exe -f -q -v “9” -t “$siteToken”
Under the variable section of the script we set it to siteToken, variable type platform, value - our customer field with the sentinel key. Change the destination file name/path to what you need it to be.
It runs fine. We do get an error that it fails, HOWEVER, it does install it as expected.
