I assume we don’t have a way to search blank fields in Saved Asset Search? So I am requesting it for the future:) If its because blanks don’t have any value for the code to translate - you can always just use the null, 0 , false key values for us. I assume everything is base off a SQL search at some level.
I would also like to request an OR - AND operation as well:)
But what would be cooler would be a non-gui way of doing the searches as well without having to wait for web-elements to be updated to allow for it. Sort of like a Easy Mode and Advance Mode. This way even if its not possible to do in easy mode - at least there is a fall back with the advance mode.
