We should be able to Search and have results that include a given customer’s previous tickets.
According to Andy Cormier, I need to add this to this “Feature Requests & Suggestions” in order for it to be “considered” or added to the apparently “secret” Top 5 Requests List.
Can you help me convince Syncro that searching for previous ticket notes within a customer record is critical to fixing problems and referencing information? Upvote or whatever they’re asking for this to be heard; I would appreciate it.
Absolutely this should be implemented.
Not sure what is harder to believe.
That this isn’t already possible or that Syncro needs convincing that it should be possible.
Note to self…before we move from using RangerMSP for ticketing to Syncro for ticketing, make sure the API can retrieve ticket notes data.
You can do this using API somehow.
I have a programmer on our team and he has put together a little custom application that gives this functionality and it is VERY handy
I don’t have dropbox.
I’m not likely to either.
We are heavy users of Onedrive and Sharepoint.
It is ok, now that I’ve heard it can be done with the API, I will do it with the API in a desktop app.
