Scripts need a instructions section visible when running
When my team is running scripts one-off I would like to be able to display instructions for them. Sometime you can’t name the runtime variables well enough to get across what they are to be used for. Also sometimes there are some prerequisites to running the script, like the asset must have a contact assigned to it because we’re using the contacts email as a username. I have entered a lot of this stuff in the descriptions, and have also had to add in some error checking to the script and spit out the errors in the script output. However it seems silly to have to give someone directions in the script output when it could have been surfaced before they ran the script.
yep I’ve thought of this several times, good feature request
