Script to reboot, login and execute a startup script, stay logged in
I have a workstation that needs to have a ‘service’ run that requires a user to log in and run, usually windows is locked after it runs so stays open. I created a simple script that runs ‘shutdown /g /f’ and I have the batch file in the startup folder. It seems to run if I run the script one by adding to the queue on the workstation but it does not seem to login and run the batch if I schedule to run every Saturday at 3 am. It reboots but does not start the batch so I have to manually login and run. Any idea why? Or what I can do to run? I have to do since updates run on that PC on Saturdays at 12 am and it’s usually reboots after.
Had a hard time following all that but I’ll take a stab. I’m not sure /g works in domain environments. It’s possible it doesn’t process Startup folder also for some reason. You might look into using GitHub - KelvinTegelaar/RunAsUser: a PowerShell module that allows you to impersonate the currently logged on user, while running PowerShell.exe as system. to run whatever it is without being logged in as them.
Workgroup environment. The program has to stay running, like running a script as logged in user, not just excuting it once as a particular user, the program is not a service and has to keep running, basically a data broker looking for changes in certain folders. I’ll look into this to see if it can be used, thanks Isaac
