Script Success but no output
Hey ,
i run this script in PS without any problem.
when i try in Syncro i have no fault but also no Output, only a black line
what’s wrong ??
function Get-DesktopShortcuts{
    $Shortcuts = Get-ChildItem -Recurse "C:\users\$env:UserName\Desktop" -Include *.lnk
    $Shell = New-Object -ComObject WScript.Shell
    foreach ($Shortcut in $Shortcuts)
        $Properties = @{
        ShortcutName = $Shortcut.Name;
        ShortcutFull = $Shortcut.FullName;
        ShortcutPath = $shortcut.DirectoryName
        Target = $Shell.CreateShortcut($Shortcut).targetpath
        New-Object PSObject -Property $Properties
[Runtime.InteropServices.Marshal]::ReleaseComObject($Shell) | Out-Null
$Output = Get-DesktopShortcuts
$Output
Now i write the output first to a file and then upload to the asset
Now it works
Doesn’t work because you can’t output that type without changing it.
Change $Output to:
($Output | Format-List | Out-String)
Or remove the FL if you want, but it cuts off because of the length, but either way, that’s what you need to get it to display.
