Script history disappearing
I’m noticing a small number assets across a range of customers now have an empty script history. Completely blank.
I’ve logged a support ticket with a specific example.
But in the meantime is anyone else noticing assets with blank script histories?
ahhh, never mind.
I realise now that it was likely my fault.
A small number of impacted customers didn’t have our weekly maintance policies applied, therefore the weekly scripts never ran and hence the script history is empty.
Happens:) good job finding the issue
yes, these things happen.
Unfortunately determining the scale of the problem by auditing all the policy folders and their policy assignments across the entire customer base is sadly a tedious task. :sob:
If only policy management was supported by the API. Then I could write a script to produce a report and eyeball all the customers to see if the policy folders looked ok.
