If you try running a script and get the error "Script failed to run because required files could not be downloaded," in most cases it is because you did not enter the full pathname + file name where you want to store the file. See the below example.
To fix this,
- Edit the script.
- In the Destination File Name (full path) field, fill in the entire pathname + script file name.
- Click Update Script.
- Try running the script again.
