Running a script every morning
What would I configure if I would like a script to run on certain assets every morning. Would it be under set up scripts → run if not run within 1 day? Thanks
From your screenshot it looks like you’re trying to tie this recurring script to a policy. This policy setting will run the script the first time the agent is installed to setup the asset. It won’t run again. What you’ll want are Script Schedules. Here is a quick example:
This script will run every morning at 8 AM. I’m using the ‘Skip Offline Assets’ option here. If this setting is disabled instead, the script will run when the computer is offline. The script will be in a pending state until the machine comes back online and then the script will run right away.
Ah thanks. I knew it was somewhere.
Also, is there a way to set this up in a policy? Like if you have this policy, run this script every day at 6am?
Yup, the screenshot comes from the scripting section of policies.
