Run functions outside of asset
Because there are no options to set archived status - I created a policy to set archived status. The problem is I need to have it run the script so it sets the status correctly. So it would be nice to have the ability to run script in some type of “Offline Mode” if the device is running or not. Granted, I know this means we can’t run scripts - but some method to run Synco built in functions instead - such as setting a variable in the assets.
Right now, I have to make sure either I set it or be lucky enough the device is online still when setting it before it gets remove or whatever else happens to it.
