I Have a 4 request and suggestion in Syncro reports 1. If its possible if the overview and assets can generate a report or possible to copy in Executive Builder Reports? 2. also it can be possible to customize Customer RMM? 3. when I add New Customer Field under Syncro Device Custom Fields and if the field type is Date Type it is not appear when it come to customize the list summary section > Configure list Block > Sorted By can you add and lastly can you also customize the days of user agent offline not online for 30 days or a month it can be possible if we arrange it by 5 days or something? Hope you will help me with this request Thank you!
