Hi there, is there a way to limit reports not by number, but by option and even with logic like ‘is’ or ‘not’. For example, I want to build a report that lists all machines not a specific Windows version. Currently, all I can do is build a report ordered by OS version and order it ascending/descending then choose how many computers I want it to list before limiting.
Am I missing a trick here or is there no way to build reports that report things like OS versions yet?
You would go to Reports → Internal Report Builder → New Report Template and then you can point to your saved asset search. Other reports may allow you to pick a saved asset search as well, but you’d have to check them
