Remote Access (built-in Splashtop for clients) is enabled somewhere
I just noticed that I’m getting billed for 2x remote access licenses. I don’t know where they are and I don’t see a way to do an asset search to find them. Anyone know how I can figure out which assets have remote access enabled in order to disable it?
This report is supposed to do that, I have found it to not be very accurate however. But may help you?
That worked, thanks!
The one trick was that one of the users listed was the primary contact and it was disabled for them as a normal contact but enabled at the customer level.
