We are looking for something similar to WDS via Syncro. Our goal is to have the ability to reimage laptops remotely. Currently, we have sysprep images for different models of laptop but we are forced to create a WDS server on site at every customers location.
Is there a better way to handle this scenerio?
Does Syncro natively work with sysprep images?
Do we need to enable any add-on or purchase any software to make this work?
Not sure if this meets your specific requirements but we use it mainly for the Bulk enrolment for AAD. When you create the PPKG you could have syncro deploy and run the setup.
