QOL - Sort alerts by type
Would like to be able to sort the “alerts” page by check type so I could clear similar ones faster.
You can search for them now using the “Check Type.” Would you rather see a dropdown like in Automated Remediation where you can select them on and off?
@Andy
Looks like the request is for sort not search.
The feature request would be solved if the column Check Type was made to be sortable.
@Andy just if the page itself were sortable. Customer, Asset, Updated, Created are all sortable.Check Type would be awesome. Tiny QOL I realize…
I would like to see all of the columns sortable (barring the “Remote”) column on the RMM Open Alerts Table.
Under Tickets there are the possibility’s for Groupings. a similar Option for the Alerts would be nice.
We have some Alerts that doesn’t require a ASAP action so a Grouping would make the view more cleaner.
