Push module.psm1 file to machines that are missing it?
Our CrowdStrike AV has a tendency to snipe the module.psm1 file that Syncro uses every once in a while. Sometimes I can release it from the quarantine, but occasionally I’m not able to or we miss one. Is there a way to have Syncro check the all our assets for the file and push it back down to any that are missing it?
I think Syncro replaces it, but when, I’m not sure. Maybe try forcing a full sync?
I deleted the file on my machine to test and a sync didn’t do it, but right as you commented I tried restarting the Syncro services on my machine and the file re-appeared. So I guess restarting would do the trick if needed.
