Policy Inhertiance Issue
Hello, I have an issue where a PC (asset) keeps getting Webroot installed after I remove it. The parent policy for the full company is set to check for and install Webroot if missing, but I have a different policy set on this particular asset that’s supposed to have no AV.
Could be my lack of understanding of how policies work, but shouldn’t the policy set on the asset override the parent? If not, how do I go about setting this up so there’s a different policy on a particular asset?
Did you select Disable Antivirus or just left it off the policy? Most things override the parent, some things add, but this one will definitely override. If you view the Effective Policy of the asset, it will give you an idea of what’s going on.
